Wtd: 5 Speed Flywheel Bolts
Vehicle: 01 Tiburon
It is not advisable to re use flywheel bolts due to their easy-to-strip head design. It is recommend to be changed every time the flywheel is removed or just replace the ones that have been damaged when it was taken out. You might as well pick some up from the dealership, it should be around $3 each. All the RD's uses the same bolt
thanks man i didnt know that. i was weary of it reusing torque converter bolts on my auto even . then my dad being the old man he is said it was fine.
are there 3 of them or is there more on a standard? ill just search thanks.
edit: searched and there are 6 just for reference if anyone needs it.
