WTB-SlimLine radiator fan, needed ASAP!!!
Ok, I really need a slim radiator fan. If someone has one for sale, or knows where I can get one, I'd really appreciate it.
The reason I need one is because the Maintec GT Headers won't fit because the radiator fan is to big. Yes, boys and girls, if you've got these headers, you MUST get a slimmer rad. fan. No if's, and's, or but's about it.
REDZ, if you read this, either you or David need to add a little disclaimer to the product page.
The problem is that they go out too far. Whereas normal headers usually go straight down(sorta), these go out, arch upwards, go out a little futher, then arch downwards. The biggest problem is the stupid fins on the stock fan.
I know a guy that sells these for $60 each shipped, 12"x12"x2.5" dimensions, I think he said they flow around 1200-1400cfm. I bought a couple myself, but have not installed them on my car. I hooked them up to an old battery and they definately flow wink1.gif. If you're interested let me know and I'll see what I can do. I can also take some pics if you want.
Ultra - How think are they? I think HP lists them as 3" thick, which I don't think is too much thinner than the stock ones.
a_gut -I'm definitely interested in those. Pics would be great too.
Well I just ordered them last week. I should get them this week. I will measure the stock ones tomorrow and let you know the difference once the new ones come in. Tim (speed-factor) said that if you really want room to mount them on the other side of your radiator. You would probably need to take off the bumper to do this.
-EDIT-
Here are the specifics from Flex-a-lite's site on the 220 fans:
Size: 15 1/2" x 26 1/4" x 2 5/8"
Diameter: 2 x 12"
Speed: 2000 RPMS
Airflow-Cu. Ft./Min. at 0º Static Pressure: 2500
Amp Draw: 19.5
Mounting System: Thru Core or Bracket
Adj. Thermostat 180º-240º: No
Air Conditioning Relay: No
Number of Blades/Fan Blade Angle: 10/21°
-EDIT-
Diameter: 2 x 12"
Speed: 2000 RPMS
Amp Draw: 19.5
dude i suggest getting them from here...http://www.precisionracingonline.com/bulk_...bb/fans_bb.html tell them that chris sent yah we'll take care of yah over at pro...thanks Chris oh yeh and if you want more info let me know I can get tons..chris
