Wtb: Short Shifter (early 01), Clear Corners, Ngk Spark Plug Wires
Vehicle: 2004 Tuscani Tiburon
hey ive got an early model 01 tiburon and am looking at buying a short shifter, clear corners, and spark plug wires as the title says. i have an 01 tib but i believe i need an 00 set up for the shifter as ive been looking around and the early 01s are different. I live in Canada.
thanks.
thanks.
Not sure if he's parting out, but I think he's up for a trade part-out, check this guy's thread: http://www.rdtiburon.com/index.php?showtopic=29246&hl=
Spark plug wires I'd recommend just getting new. The price difference isn't that much (assuming you could find a used set), and it's worth getting them new in the first place.
Check out the DIY clear corners, I did it and think it looks great. Be sure to get silver covered bulbs though.
And I think RedZman has a short shifter?
thanks man. and if the DIY ur refferring too is the one where u put it into the oven and take the lens off? cause i tried that with a spare light and i couldnt get it to stick back together and the headlight was ruined. (it was an extra anyway) and yeah i was going to get new wires, just seein if any one had any for sale that are fairly new. ill check out that short shifter tho.
Not to hijack your thread or anything... But I assume you are referring to the clear corners, not the headlights? In either case, if you get it apart, you have to use clear silicone caulk to get it back together. With the corners, you can't just put it back in the oven and have it stick. The headlights use more of a soft glue thing, but the corners are a much harder, more brittle glue, so reheating it won't work. The only tricky part with that is not cracking the clear lens, but if you've already gotten that off, that should be the end of your troubles.
Try to find the DIY in here, that explains it all really well.
All RD's use the same Short Shifter, the "rumored" white shifter base RD is a myth.
Go to pretty much any parts store for the wires. NGK # 7962
http://www.ngksparkplugs.ca/partfinder/results.cfm
QUOTE (BLK2KTIB @ Oct 20 2008, 10:15 PM)
yeah i got all the sites for new ones of those parts i was just seeing what kinda numbers i could get on here. i found a canadian site to get my wires off of even.
Please dont' quote the post above yours, use "ADD REPLY" at the bottom of the page, or delete the quote before posting.
If you want everyone to know you are for sure just replying to the above post use ^^^^ at the beginning of your post.
