Wtb: O2 Sensor Plug 1997 Only
well, i'm at my last resort. if anyone can help i'd be grateful. i found a 1999 but the plugs on it are the newer kind.
poor things. lot of good parts on them though. frames and engines looked good too.
Got a pic of what you need? Its a 4-wire? Just post a pic since almost all of us have the "newer style"
Why not get a new style plug and a new style O2 sensor? I guess it would cost a little more but you could probably even get a used O2. Just a thought.
that's the hard part, they changed the 4-pin wiring order and female-male connector plugs in all models in 1998+. i've tried my best to get the right wiring order but nothing works, so i'm converting everything to how it was before and i don't want to change any order so i can be sure.i cut the socket out accidently years ago. two other folks have a similar problem.
the socket is like the RD2 one but with a hollow center. the pins should be located in the socket rather than the other way around.
thanks though...
thanks though...
