Wtb: Hub Assembly
I need to find a driver side front hub assembly (not just the wheel bearing) for an '01. Specifically i need the piece with the lugs attached to it that goes inside the bearing and connects to the axle. However since that's pressed into the bearing and hub assembly, I'll take the full assembly as well if someone has it. If I can't find it here I'm going to be reduced to buying it from the dealer for a ridiculous price, since no junk yards around here ever have tibs.
Let me know and name your price with shipping to 49401 if you've got it.
Thanks
Thanks
Have you looked at the usual suspects man? Car-Parts.com or the like?
There are several full part outs right now too, but the local pick and pull is the best. I got both of my full assemblies for under $100.
I explained what part I need in the first post.
Red I'm checking those options as well, not having luck so far.
QUOTE (1997tibby @ Aug 17 2009, 01:28 AM)
hey your in luck I happen to be parting out my ENTIRE CAR and have excatly what you need :-) PM me if ur interested
Actually you're just a bit late, ended up having to go to the dealer to get it.
Thanks though!
