Passenger Air Bag Cover
Vehicle: 2001 Tiburon
i was thinking of asking you in your thread but I wanted to see if anyone just had one laying around first because its a major PITA to get the damn thing out. You have to take out the glove box first then all the bolts for the airbag console itself which are the hard part. The ones at the top are the hardest, you can barely get a socket in there unless you have an extension with an elbow joint maybe.
I don't care if the thing bolts back in really so if you wanted to just take a sawzall blade to cut the plastic tabs that hold it in place at the top I would still take it as long as you don't cut into the cover itself.
Photobucket
Photobucket
If the one you want is the same as a 98 elantra, I've got one for you:
(make an offer)
http://www.rdtiburon.com/index.php?showtopic=29551
Getting these out basically means the entire crash pad has to be removed. It's a bit of a hassle.
(make an offer)
