OEM ECU for tib(can be broken or good)
Re: Best Cheap OEM Mod Yet... *Teaser*
I'm looking for a cheep OEM ecu from a tib or a elantra, it makes no difference if its a 1.8 or 2.0 as long as the plug on it is the same as my '01 tib, it does not have to be a working item as long as it looks in good shape from the outside I don't care about the electronics on the inside since the will be ripped apart anyway.
Re: Custom Plexiglass Spare Tire-well cover
Well I'm gonna be installing a standalone ecu soon and wanna be able to pass inspection, I have a perfect power prs-8 and it will work with all the stock sensors and wiring but I don't wanna cut the plug from the factory ecu harness or run a million new wires. I wanna take a factory ecu and gut it out so I can mount and wire the standalone straight to it so I can just unplug the stock ecu and then plug the standalone right into the factory harness and when it comes time for inspection I can just plug the stock ecu right in and stick in the stock injectors for a day or two untill the inspection is over plus it would be nice to have a backup system in case the standakone burns out 200mile away from my house. I think it should work.....
Re: worried brit...................
I got a 2.0 ECU that I can spare. Can you do $50 shipped? Let me know
edit: oh yeah, I really wouldnt have to ship it. I could just hand it to you, its in Deer Park. So make it $40.
Re: OEM ECU for tib(can be broken or good)
Well I gotta have my boyfriend take it out cause its at his shop, so I'll let you know when I have it. Probably this weekend would be good. Although its Christmas...well when would be good for you?
Dang they really inspect it hard. All they did with mine was make sure i had vin code right and look at my engine they didnt give a crap about anything.
every once in awhile they will have them on ebay. here you go.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...ssPageName=WDVW
