Need Some Help
Old 04-17-2008 | 09:45 PM
stealth's Avatar
Vehicle: 2000/Hyundai/Tiburon
ok i will go get it
brb
ok well its # 880443 and its a nylon space .562 x .375 x 1/2 and it looks like this
http://i296.photobucket.com/albums/mm199/t...ff/100_1721.jpg
http://i296.photobucket.com/albums/mm199/t...ff/100_1722.jpg
http://i296.photobucket.com/albums/mm199/t...ff/100_1724.jpg
hopefully that helps
Old 04-18-2008 | 01:38 AM
drkzero83's Avatar
lol, i just re-read what i wrote up there found like 3 spelling mistakes lmao.gif
i'mma go to lowes tomorrow and look for that bushing thanks yellowlightning
Old 04-18-2008 | 08:35 AM
stealth's Avatar
no problem they come in packs of two so im just going to leave one in my glove compartment in case mine goes bad but so far its amazing how much of a difference that short shifter makes the bearing was a little hard to get on so i just greased the shifter where it goes on and took a hammer and took a little bit of muscle to get it on but it when on nice and snug and shouldnt be falling off anytime soon so hopefully it works for you
Old 04-18-2008 | 08:45 AM
StrikeEagle's Avatar
That's something I was also wondering about, since it doesn't 'snap' on like the previous one, do you think there will be any chance of it falling off?
Old 04-18-2008 | 02:58 PM
stealth's Avatar
hm... good question it went on very snugly so i assume with as hard as it was to get on its probably going to stay but if it does fall i will update on it so far its been great did a few hard power shifts today and its still holding up strong seems very sturdy and nice but i will keep you updated on it
Old 04-18-2008 | 03:07 PM
Just got back from lowes, had a bugger of a time finding it. I eventually gave up and went to the hardware dept for something else and saw the drawers with this stuff in it. Sure enough, there it was!
Got back and tried to install it, and it didn't really fit... the ID was too small, so it didn't really fit over the end and the OD was also too small so there was a lot of slop. I ended up just using the one I had, but wrapped it in teflon tape. PEFRECT FIX!!! Everything is absolutely tight now, no wiggle at all. I put teflon tape on most the other joints as well, and it completely fixed it! I may do a writeup as to what I taped, it was about 6 different places. Now I'm just hoping this stuff will hold up.
Old 04-18-2008 | 08:09 PM
stealth's Avatar
lol hm... mine works fine i suppose it was too small but i didnt notice any slop (although my clutch is shot anyways so idk if i am just used to it) but i think im just going to put a rubber hose around it so that it is in there tight and see how that works out i will get back to you on that
