00-01 Tib Front Hub Assembly!
ok I have read before that you can swap the hub assembly off a 97-00 elantra because their non captive, so the hub assembly of a 00-01 tiburon would work too?
damn it, this was wat came up on the search ill post somewhere else.
you're also going to need caliper brackets with the other parts. it has to do with w/ the non captive setups, the rotor is basically pushed out farther. caliper is the same, however
i just recently did this on my car
What (wat) does any of this have to do with the wanted section Tony?
You have 88 posts now, you should know better. Warned.
