tiburon 4wd
Vehicle: 1991 Impulse RS
Vehicle: 2000 Tiburon
it would be easier to put a Prius's MG1 and MG2 with trans and diff in the back of a tib, charge it with the front engine and have an ev Tib with 300 awd, than to use a Santa fe drivetrain.
Vehicle: 2000 tib
4 wd tiburon
I must have posted this a dozon times over the years to this same question.................
It's a lot easier than you might think if you have the skill. 15K! WTF! This guy did it for $5500 CDN. (same idea)
http://honda-tech.com/showthread.php?t=2763036\
If you have the time, $$$ and skill, you can do anything.
that's not the same, he took the body of a civic and put it on a wrx. I'm talking about taking the engine, transmission, and rear end, and swapping them into a full bodied tiburon. I want to keep the exterior and interior from the tib.
The 1G Eclipse has the same wheelbase as an RD and uses the same motor/diffs out of an EVO (3 iirc) so that is a much more likely scenario. I believe that's what they used to build the one Regit posted.
