Ps3
ok soo im going on a info raid to get as much info on it as possible.
May 16, 2005 -
Product name: PlayStation 3
Logo: PLAYSTATION®3
CPU
Cell Processor
PowerPC-base Core @3.2GHz
1 VMX vector unit per core
512KB L2 cache
7 x SPE @3.2GHz
7 x 128b 128 SIMD GPRs
7 x 256KB SRAM for SPE
* 1 of 8 SPEs reserved for redundancy
total floating point performance: 218 GFLOPS
GPU
RSX @550MHz
1.8 TFLOPS floating point performance
Full HD (up to 1080p) x 2 channels
Multi-way programmable parallel floating point shader pipelines
Sound
Dolby 5.1ch, DTS, LPCM, etc. (Cell- base processing)
Memory
256MB XDR Main RAM @3.2GHz 256MB GDDR3 VRAM @700MHz
System Bandwidth
Main RAM 25.6GB/s
VRAM 22.4GB/s
RSX 20GB/s (write) + 15GB/s (read)
SB< 2.5GB/s (write) + 2.5GB/s (read)
System Floating Point Performance
2 TFLOPS
Storage
Detachable 2.5" HDD slot x 1
I/O
USB Front x 4, Rear x 2 (USB2.0)
Memory Stick standard/Duo, PRO x 1
SD standard/mini x 1
CompactFlash (Type I, II) x 1
Communication
Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T) x 3 (input x 1 + output x 2)
Wi-Fi IEEE 802.11 b/g
Bluetooth 2.0 (EDR)
Controller
Bluetooth (up to 7)
USB 2.0 (wired)
Wi-Fi (PSP)
Network (over IP)
AV Output
Screen size: 480i, 480p, 720p, 1080i, 1080p
HDMI: HDMI out x 2
Analog: AV MULTI OUT x 1
Digital audio: DIGITAL OUT (OPTICAL) x 1
Disc Media
CD PlayStation CD-ROM, PlayStation 2 CD-ROM, CD-DA, CD-DA (ROM), CD-R, CD-RW, SACD, SACD Hybrid (CD layer), SACD HD, DualDisc, DualDisc (audio side), DualDisc (DVD side)
DVD: PlayStation 2 DVD-ROM, PlayStation 3 DVD-ROM, DVD-Video, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW
Blu-ray Disc: PlayStation 3 BD-ROM, BD-Video, BD-ROM, BD-R, BD-RE
i found pics.....
Movies!!!!
Im getting them from streams right now. ill post them as soon as possible! promise.
Devil May Cry 4
Formula 1
PS3 to change E3
May 16, 2005 -
Logo: PLAYSTATION®3
CPU
Cell Processor
512KB L2 cache
7 x SPE @3.2GHz
GPU
RSX @550MHz
Sound
Memory
System Bandwidth
Main RAM 25.6GB/s
VRAM 22.4GB/s
2 TFLOPS
Storage
I/O
Communication
Bluetooth 2.0 (EDR)
Controller
Bluetooth (up to 7)
USB 2.0 (wired)
Wi-Fi (PSP)
Network (over IP)
AV Output
HDMI: HDMI out x 2
Disc Media
i found pics.....
Movies!!!!
Devil May Cry 4
Formula 1
PS3 to change E3
PlayStation 3 announced for 2006
[UPDATE 10] Sony unveils its next-gen console in LA; Metal Gear Solid 4, Devil May Cry 4, Tekken 6, Gran Turismo 5, and Warhawk remake confirmed. First pictures and video inside.
screenshot
more screens (8)
View the slideshow »
Screenshot Index »
LOS ANGELES--Today saw the second of the big three console makers announce its next-generation platform. At its pre-E3 press conference, Sony Computer Entertainment gave the world its first look at the PlayStation 3, as it now is officially called. While the device's price has not yet been set, its release window--spring 2006--has. Flanked by Sony Computer Entertainment America President and CEO Kaz Hirai, SCE head Ken Kutaragi introduced it as a "supercomputer for computer entertainment."
The name was not unexpected, since Sony had been running an extensive teaser-ad campaign prepping the public for the PlayStation 3. The company had laid a blanket of posters around the Los Angeles Convention Center, site of the Electronic Entertainment Expo (aka E3). Bus stalls and billboards around the convention center proclaimed "Prepare for Chang3" in the distinctive PlayStation font with partial shots of the Dual Shock controller's square-circle-triangle-X buttons.
Sony also confirmed the PlayStation 3 will use Blu-ray discs as its media format. The discs can hold up to six times as much data as current-generation DVDs. It will also support CR-ROM, CD-RW, DVD, DVD-ROM, DVD-R, DVD+R formats. Sony also confirmed the machine would be backward compatible all the way to the original PlayStation. It will also have slots for Memory Stick Duo, an SD slot, and a compact flash memory slot. It will also sport a slot for a detachable 2.5-inch HDD, somewhat similar the Xbox 360's. Sony did not mention if the drive would be standard.
Sony also laid out the technical specs of the device. The PlayStation 3 will feature the much-vaunted Cell processor, which will run at 3.2GHz, giving the whole system 2 teraflops of overall performance. It will sport 256MB XDR main RAM at 3.2GHz, and it will have 256MB of GDDR VRAM at 700MHz.
Sony also unveiled the PS3's graphics chip, the RSX "Reality Synthesizer," which is based on Nvidia technology. The GPU will be capable of 128bit pixel precision, 1080p resolution, some of the highest HD resolution around. The RSX also has 512MB of graphics render memory and is capable of 100 billion shader operations and 51 billion dot products per second. It also has more than 300 million transistors, larger than any processor commercially available today. It will be manufactured using the 90nm process, with eight layers of metal. The RSX is more powerful than two GeForce 6800 Ultra video cards, which would cost roughly $1,000 total if purchased today.
The PlayStation 3 will also sport some hefty multimedia features, such as video chat, Internet access, digital photo viewing, and digital audio and video. Speaking of video, Sony Computer Entertainment's Chief Technical Officer Masa Chatani was on hand to show off the PS3's panoramic video functions. Since the console has two HD outputs, it is can be hooked up to two side-by-side HDTVs to projecting video in a 32:9 extra-widescreen format (think Cinemascope in your living room). Like a gigantic version of the Nintendo DS, the dual digital outputs also allow for an extended game display, with the action on one screen and either game information or video chat on the second.
Out of the box, the PS3 will have the capability to support seven Bluetooth controllers, which can be used for nearly 24 hours before they require charging. Later, pictures of the controllers themselves were released, showing their almost boomerang-like shape. It will also have six USB slots for peripherals: four up front and two in the back. As rumored, it will also have Wi-Fi connectivity to the PSP, which can be used as a remote screen and/or controller.
Dr. Richard Marx, the inventor of EyeToy, was on hand to show off the PS3's wireless HD IP Camera. The demo, recalled rumors that the machine will have Minority Report-esque motion-sensing capabilities. Marx held two small cup-like objects in his hands, which move the cups on the screen in real time.
To show off the PlayStation 3's graphical brawn, Sony showed several game demos, including an Unreal 3 engine show-off of what appeared to be Unreal Tournament 2007. In what must come as a relief to developers, Epic Games' Tim Sweeney was on hand to vouch for the PS3, saying it was "easy to program for" and that Epic had received its first PS3 hardware two months ago. He proved the tech demo was real time by showing it again and by manipulating the camera and zooming in.
However, Sweeney's words were only the beginning. Later, Sony trotted out a whole host of publishers that are backing the PlayStation 3. And in the process, it confirmed several games for the console. Hideo Kojima introduced Konami's Metal Gear Solid 4, Capcom showed off Devil May Cry 4, Namco unveiled Tekken 6, Polyphony Digital trotted out a fifth Gran Turismo, SCEE showed off the next Killzone, and Rockstar Games showed a new Red Dead Revolver.
EA President Larry Probst was also on hand to show off a demonstration of the next Fight Night game, which will presumable be called Fight Night Round 3. When one of the two fighters took a blow, his skin rippled realistically. Kudo Tsonoda from EA's Chicago studio was on hand, and said that the goal is to make the facial animation convey the amount of punishment a pugilist has suffered.
And still the games came. SCEE had three on display: A third Getaway, with an even seedier, nastier version of London; a new off-road racing game called Motor Storm from Evolution Studios; and a shooter called Heavenly Sword. Sega is readying a fifth Phantom Saga and Bandai is prepping another Gundam game. Ubisoft is continuing to innovate in the first-person shooter field with an all-new IP named Killing Day. Koei enlightened the crowd with a demo of Ni-Oh, a new martial-arts-themed brawler about Buddha's monk bodyguards. Incognito is developing a sequel to Warhawk, the acclaimed actioner for the original PlayStation.
screenshot
more screens (8)
Screenshot Index »
also want to add..... that a 05 release isnt out of the picture aparently from ign...
and info on the blue ray.
http://home.btconnect.com/hgi/ps3/ps3bluray.html
In a surprising twist on the next generation hardware race, a Sony representative has stated that a year 2005 release for the next generation PlayStation is a possibility. Responding to questions from Jiji news service, Sony Chief Financial Officer Takao Yuhara states, "For the year end sales season, simultaneously building up both the PlayStation Portable system in America and Europe as well as the next generation PlayStation is one option that we have."
Most industry speculation calls for a next generation PlayStation release in 2006. Sony's third party developers have backed this assumption up with a strong list of PlayStation 2 titles planned for the rest of the year and early next.
The state of the next generation PlayStation software shown at next week's E3 show should reveal if a 2005 release is a possibility for the new system, or if Yuhara's comments were designed to take some steam out of Microsoft's Xbox 360 unveiling later today.
Wow.
It still looks like a futuristic briefcase.
3.2 GHZ? I thought it was supposed to be higher?
And the controller, MS should sue them, that looks just like their old gamepad.
Anyways, as said before, specs on all this crap will change, a dozen times or more before they come out. Like a month ago MS said the Xbox 360 wouldn't have a HD, now it's got a 20Gig HD.
Oh well.
Have fun playing Tekken 47 on that thing. Boring ass games.
Oh well.
^ All those specs are final. And I just hope they call the controller the Dual Shock 3.
Killzone 2
Gran Turismo 5
Metal Gear Solid 5
Tekken 6
Devil May Cry 4
Woohoo!!! Killzone 2 looks hot, I'm not a fan of FPS on consoles, but that looks fun.
http://www.gametrailers.com/
^ Watch the Gran Turismo movie from there! There is like 30 cars on the track at once! The best racing game ever just got better!!!
From Joystiq.com:
"Today’s Sony PS3 unveiling has opened up a world of questions regarding how Microsoft expects to maintain a competitive edge against a system that will supposedly have more than double the raw processing power... One 3.2GHz Cell processor—total system performance rated at 2.18 teraflops (uh, that’s actually about twice what Microsoft is claiming the Xbox 360 will do); it will have 256MB system RAM 3.2GHz, and 256MB GDDR VRAM at 700MHz"
Considering Microsoft came out and said their new system was a real HD system, and Sony comes out able to run 1080p (yes, progressive). That is a real blow.
Like I said before, I'll buy both, but right now, I'm more excited to buy the PlayStation 3.
WELCOME CHANG3
Killzone 2
Gran Turismo 5
Metal Gear Solid 5
Tekken 6
Devil May Cry 4
From Joystiq.com:
WELCOME CHANG3
