Macbook Air
Macbook Air
10 Convincing Reasons Why You SHOULDN'T Buy the MacBook Air
1.
Mono Speakers
For a company that can attribute much of their recent popularity to an mp3 player, you'd think the MacBook Air would be friendlier to music lovers. Instead, the only way users can hear sounds in stereo is to connect a set of speakers.
2.
No SD Slot, ExpressCard Slot, or Apple Remote
The MacBook Air just provides the bare minimum for laptops. In order to achieve average accessibility for a laptop, the MacBook Air requires several extra add-ons.
3.
One USB Port
Surely Apple would realize that most computer peripherals today are connected using USB ports. Essentially, Apple has forced consumers to make a decision. Want to connect your printer? Better take out your mouse. Want to transfer some files onto a flash drive? Better unplug that iPod (for those that think they can connect their iPods with firewire, the Air does not come with that port at all). The worst part is that the ports are non-expandable, which means that no matter how much more money you want to shell out, you're stuck with one USB port.
4.
No Ethernet
Unfortunately, the only way to connect to the Internet using the MacBook Air is through a wireless connection. An optional USB Ethernet Adaptor can be added for wired connections however its use would take up the only USB port.
5.
It's Actually Not the World's Thinnest Laptop
In 1997, Mitsubishi and Hewlett-Packard produced a laptop called the Pedion. At its maximum thickness, the Pedion measured in at 0.72 inches, compared to the MacBook Air's length of 0.76 inches. More recently, the Toshiba Portege 2000 also beat the MacBook Air with a maximum thickness of 0.75 inches. Unfortunately, neither of these computers had the marketing machine that Apple has.
6.
No User-Replaceable Parts
The hard drive, memory, and battery are all encased inside the laptop. Only the battery can be replaced, but it must be done by Apple for a fee. Other alternatives are possible but most are likely to void the warranty.
7.
Slow and Weak Hard Drive
The 1.8" hard drive only operates at 4200 rpm. On top of that, the maximum option of 80 GB is much less than the norm for laptops today.
8.
No Removable Media Drive
There is no CD/DVD player on the MacBook Air. Users can access CDs and DVDs using software called Remote Disc but it requires putting the disc in another computer. Moreover, it's been reported that Remote Disc cannot be used to install Windows, watch DVDs, or play music.
9.
Comparable Laptops Outperform the MacBook Air
Many people feel that the Sony Vaio is the closest comparison to the MacBook Air. For about the same price, the Vaio TZ does not have many of the problems above, is 40% faster, has twice as much hard drive space and is lighter than the MacBook Air.
10.
Extremely Overpriced
1.6 GHz, 64 GB hard drive, and no optical drive for $1800? 1.8 GHz for $3098? No thanks.
Source: http://www.webupon.com/Web-Talk/10-Convinc...cBook-Air.79025
1.
Mono Speakers
2.
3.
One USB Port
4.
No Ethernet
5.
6.
7.
8.
9.
10.
