Junkyard
Aight fellas, goin to the junkyard tomorrow, scoped it out today, we got some 1.8 blocks, some 2.0 blocks, some interior pieces.... list what you need and I will get it for you. List here if you need anything.
rd1 fog inserts.
and ok this is wierd. i need the metal brackets behind the plastic trunk pieces that hold the hatch cover thing. any idea what im saying? theres the pieces on each side where the little rods go in. behind those are metal brackets. i need them. i have no idea where mine went and im pissed. only get them if theyre not to much though. id spend maybe 10 or so on those and 20 for the inserts maybe. if not, dont worry about it. ill post again if i need more. thanks
If you run into any RD2s with the stock spoiler then I would appreciate if you could get...
http://www.rdtiburon.com/index.php?showtop...mp;#entry295398
ill grab a pic of where they should go or something. give me a minute
ok this page here its under quarter panel, middle column right in the middle. labeled number 17. i need both sides if possible.
