im glad this is on our side- A-10 thunderbolt
the A-10 thunderbolt, probably my third favorite plane ever, (p51, blackbird come first i think)
THE A-10 -- HOW IT CAME ABOUT
What a weapons system!!!
First there was this gun...
It was developed by General Electric, the "We bring good things to life" people.
It's one of the modern-day Gatling guns. It shoots very big bullets. It
shoots them very quickly.
Someone said, "Let's put it in an airplane."
Someone else said, "Better still, let's build an airplane around
it."
So they did. And "they" were the Fairchild-Republic airplane
people.
And they had done such a good job with an airplane they developed back in
WWII...
...called
the P-47 Thunderbolt, they decided to call it the A10
Thunderbolt.
They made it so it was very good at flying low and slow and shooting things with that
fabulous gun.
But since it did fly low and slow, they made it bulletproof, or almost so. A lot of
bad guys have found you can shoot an A10 with anything from a pistol to a 23mm
Soviet cannon and it just keeps on flying and
shooting.
When they got through, it looked like this...
It's not sleek and sexy like an F18 or the stealthy Raptors and such, but I think
it's such a great airplane because it does what it does better than any other
plane in the world.
It kills tanks.
Not only tanks, as Sadam Hussein's boys found out to their horror, but armored
personnel carriers, radar stations, locomotives, bunkers, fuel depots...just
about anything the bad guys thought was bulletproof turned out to be easy
pickings for this beast.
See those engines. One of them alone will fly this puppy. The pilot sits in a very
thick titanium alloy "bathtub."
That's typical of the design.
They were smart enough to make every part the same whether mounted on the left side
or right side of the plane, like landing gear, for instance.
Because the engines are mounted so high (away from ground debris) and the landing gear
uses such low pressure tires, it can operate from a damaged airport, interstate
highway, plowed field, or dirt road.
Everything is redundant. They have two of almost everything. Sometimes they have three of
something. Like flight controls. There's triple redundancy of those, and
even if there is a total failure of the double hydraulic system, there is a set
of manual flying controls.
Capt. Kim Campbell sustained this damage over Bagdad and flew for another hour before
returning to base.
But about that gun...
It's so hard to grasp just how powerful it is.
This
is the closest I could find to showing you just what this cartridge is all
about. What the guy is holding is NOT the 30mm round, but a "little" .50 Browing
machinegun round and the 20mm cannon round which has been around for a long
time.
The
30mm is MUCH bigger.
Down at the bottom are the .50 BMG and 20x102 Vulcan the fellow was holding. At the
bottom right is the bad boy we're discussing.
Let's get some perspective here: The .223 Rem (M16 rifle round) is fast. It shoots a
55 or so grain bullet at about 3300 feet/sec, give or take. It's the fastest of
all those rounds shown (except one). When you move up to the .30 caliber rounds,
the bullets jump up in weight to 160-200 grains. Speeds run from about 2600 to
3000 fps or so.
The .338 Lapua is the king of the sniper rifles these days and shoots a 350 grain
bullet at 2800 fps or so. They kill bad guys at over a mile with that
one.
The .50 BMG is really big. Mike Beasley has one on his desk. Everyone who picks it
up thinks it's some sort of fake, unless they know big ammo. It's really huge
with a bullet that weighs 750 grains and goes as fast the
Lapua.
I
don't have data on the Vulcan, but hang on to your
hat.
The bullet for the 30x173 Avenger has an aluminum jacket around a spent uranium core
and weighs 6560 grains (yes, over 100 times as heavy as the M16 bullet, and
flies through the air at 3500 fps (which is faster than the M16 as
well).
The gun shoots at a rate of 4200 rounds per minute. Yes, four thousand.
Pilots typically shoot either one- or two-second burst which set loose 70 to 150
rounds. The system is optimized for shooting at 4,000
feet.
OK, the best for last.
You've got a pretty good idea of how big that cartridge is, but I'll bet you're like me
and you don't fully appreciate how big the GA GAU-8 Avenger really
is.
Take a look...
Each
of those seven barrels is 112" long. That's almost ten feet. The entire gun is
19-1/2 feet long.
Think
how impressive it would look set up in your living
room.
Oh,
by the way, it doesn't eject the empty shells but runs them back into the
storage drum. There's just so dang many flying out, they felt it might damage
the aircraft.
Like
I said, this is a beautiful
design.
it."
people.
WWII...
...called
Thunderbolt.
fabulous gun.
shooting.
plane in the world.
It kills tanks.
returning to base.
This
time.
The
3000 fps or so.
one.
Lapua.
I
hat.
well).
feet.
is.
Take a look...
Each
19-1/2 feet long.
Think
room.
Oh,
the aircraft.
Like
design.
one thing also...
it can also carry 20,000 lbs. of bombs while still flying at 450 mph. the "Warthog" as it is effectionally nicknamed, is BY FAR my favorite military aircraft ever since i was a kid. I did a paper about this plane also in high school but never knew the main gun was that damn big. but, back then the plane was still classified so to speak and was damn near mothballed but it was brought back in 1991 during desert storm.
back when i was building water and oil storage tanks, I was helping build the water tower that is at the gunnery complex at ft. riley. while we were capping the tank we had two warthogs fly over us. we were roughly 150 ft. up and they passed so close i could literally see one if the pilots wave to us as he dipped his wings back and forth.
yeah, they can bring a chill to your spine just looking at them, let alone have one of them bastards shooting at you, lmao.
