Which wire for TPS in ZEX kit?
Alright, I am not sure if this should be in the HELP Forum, or here..
Anyway, I have a ZEX kit, and I am installing it tomorrow... I need to know. Which wire in the Throttle Positioning Sensor gets spliced into from the White wire from the ZEX box. PLEASE give me an answer ASAP...
IF YOU CAN.. PLEASE PLEASE PLEASE!! IM me at TSR118
Thanks in Advance..
~Matt
TSR-118
Thanks in Advance..
~Matt
TSR-118
http://www.hmaservice.com/webtech/iindex.a...id=12124#_12124
according to this , the middle wire is the ground wire. pin 1 is the tps signal.
:edit:
[ March 16, 2003, 05:29 PM: Message edited by: turbulence ]
:edit:
