Noszle system
![](https://www.hyundaiaftermarket.org/forum/images/ranks/supermod.png)
IMHO, these things are a BAD IDEA. They restrict the spray pattern of the stock injectors which leads to a less than optimal fuel distribution pattern. Also, when you are spraying fuel and nitrous around the orafice, you are going to further screw up the injector spray pattern.
Lastly, this is a horribly complicated setup. You need to run 4 seperate nitrous lines and 4 seperate fuel lines. Major Pain in the Butt.
if you are serious enough to do that, drill your stock manifold and go with a REAL Direct setup, not this mickey mouse BS....
