my car is stupid
ok i had a 100 shot direct port from nx in my tibby....never got it to work...always bogged my car down...i put a 50 shot wet kit in m car today and it did the same thing...whats wrong wtih it
well i am not to sure about nos, but just like you can send to much gas to an engine and flood it, could be the same with your set up for your car.. do you have wet or dry nitrous and I will foward your questions in my car club......
i had a direct port 100 shto set up. i have a 255 warblo fuel pump...cold air but i dunno when i hit it my car bogs down and my CEL comes one...so we tried putting a 50 shot wet kit on and it bogged down and my idel got dirasticly screwed up so i had to losen then idel adjustment nut to turn it back down any ideas
2 questions.
1. Do you have a a/f guage?
2. What was the CEL code you got?
If you dont have a a/f guage and you did not check the CEL. I am gonna smack you for being a moron.
If not, I Wanna smack you for not giving us all the information.
There are two things that can cause your problem, either you are getting to much fuel and not enough nitrous(most likely the problem) or you can be getting to much nitrous and not enough fuel(Very bad,you would have melted your pistons on the first shot). First I would take one of your nitrous jets out and spray it to see if the seloniod is working then do the same thing for the fuel. Most likely one of your seloniods is not working or you could have possibly jetted it wrong.
[ November 10, 2002, 05:49 PM: Message edited by: MAXXTIB ]
![](https://www.hyundaiaftermarket.org/forum/images/ranks/forummod.png)
The stock regulator may be having a hard time switching settings when the nitrous engages, especially with the new highflow pump. You should get an adjustable fuel regulator and a fuel gauge. When you have it installed, run the engine to make sure your psi is at 44. Then, with the nozzle disconnected, flip the switch and see if the psi stays the same when it engages.
Waiiiiiit a minute, I don't recall you saying you slapped in the Walboro 255lph unit...
If you're running THAT pump with your stock fuel regulator, you have serious problems with overfueling. Your fuel pressure is probably around 60+ psi (at least 50% too high) and thus your 245cc stock injectors are flowing about 310+cc/min... This higher pressure will also carry over to your wet fuel jetting as well.
You cannot run a stock regulator with a pump that big. You must physically remove the stock regulator (don't modify it, REMOVE IT) and buy a full-replacement external unit that can vent the significantly extra gasoline that's being pushed by your pump.
TOo much gasoline, by a long shot.
And who exactly is installing this kit? Anyone with $0.10 worth of clues would start diagnosing the fuel long before they even let you loose on the button.
![Confused](https://www.hyundaiaftermarket.org/forum/images/smilies/confused.gif)
