hiddint the nitrous
Put the bottle in a large duffel bag, cut the bag bottom appropriately to fit the lines and mounting bracket through.
Drive around 24/7 with what appears to be a leather duffel bag in the trunk at all times.
![Big Grin](https://www.hyundaiaftermarket.org/forum/images/smilies/biggrin.gif)
Vehicle: 99 Tib
u can put in back side where is kinda goes in and put a box around it and put matching carpet around it and put a latch on it then say its the "stock" sub woofer with amp.
Vehicle: 99 Tib
you say "its for when i got off roading in my fwd car"
i dunno thats what its for depends on the cop more then likey instead of giving u warning he will right you the ticket.
Guest
Posts: n/a
People People, most states axcept maybe Cali, you can get aay and it is legal to have nitrous in the car, just dont get cought with the bottle open. Now this is why if you worried about street legality you get a remote bottle opener. For the cali folks I believe nitrous in the car period is illegal. Now for the hidden nitrous crap, the speaker box idea is cool, butyou can also put a wall up behind the rear seat enough to were the bottle is between the rear seat and the wall, make the wall contour the entire trunk to make it look like you don't have split rear seats. And carpet it. As far as the solonoids in the trunk go, you can put them under the battery tray upside down or right side up. It don't matter if its and NX solonoid. As far as other kits I have no idea. I know this for sure because my purge solonoid is actually upside down and one of the install in one of the import magazines they also mounted the nitrous solonoid sideways and the fuel solonoid upside down. as for the line, I would cover it in either black conduit as red stated or cover it in a rubber vacuum hose. the nozzle attached to the intake you can make look like a temp sensor by covering that with a rubber hose and top it off with a metal fitting. The only ones who would know would be any hyundai owner. Anyone else won't think twice that you are spraying. Also the main feed line from the bottle, you run up underneath the side skirt. Taking the skirt off or at least unbolting it from the body where you need to run it is a good idea so it is completely covered.
What I have told you here has worked on several honda dealerships for warrenty repair, the only thing the guy removed was the nitrous and fuel lines from the solonoids to the intake. Every thing else including the solonoids stayed put and work was done on some bad valves without any question from the dealership about the nitrous.
Vehicle: 1997 Hyundai Tiburon FX - now 2006 Infiniti M35 Sport
Also in GA, plans were made to ban nitrous kits on public roads. They backed off a little and allowed for the kits to be in the cars as long as if the feed line was detached from the bottle.
-I always forget to take it off frown
