WTF is wrong with my car
Re: WTF is wrong with my car
<div class='quotetop'>QUOTE (rd1tib)</div><div class='quotemain'>Dont want to say anything stupid but do you have the right bulb? Because this happened to my friends car, some bulbs are use to blink only and some are used to blink and stay on. And they share the same bulb holder.</div>
Last time I checked Tibbychick wasn't blonde.wink.gif Does your friend own a Civic? (I love sterotyping Civic owners lol.gif)
Re: XBox or PS2??
brunette. Although I do have my blonde moments..
usually stupid stuff like this I can figure out which is why I was so pissed off that I couldnt fix it. :x
Re: Tell me more about manual trannies.
Not to beat this, but it IS a 1157 right? Dual filament, it has 2 leads on the bottom of the bulb(s)?
JUST making sure.
Also just making sure you didn't use the bulbs and the harness that came with the corners, but they come with 1156's, single filament bulbs and harnesses. Dunno why, but all the ones I've seen come with the same harness and bulbs when you order the corners
JUST making sure.
HMMMMM
well I didnt use the harnesses that came with the corners because they didnt fit. So I originally tried to used the bulb from the stock corners, and then the ones that came with the clear corners. And they were 1156... :x
It cant be the fuse. When that fuse blows, not only 1 light will go out. Ive had it happen before, and like 15 lights went out.
<div class='quotetop'>QUOTE (Tibbychick)</div><div class='quotemain'>:x
alright, I'll do that tomorrow first. Thanks. I shouldve fvcking realized this.</div>
Cuz if it worked before you touched it (changed the corners out to clears) there's no reason it wouldn't work after, unless you some how tugged on the harness too hard to damage it, but I'd doubt it.
