Windshield reservoir removal
Vehicle: 2010 Genesis Turbo
Re: Water Temp Gauge hook up
I was checing webtech but has nothing in detail. the thing is that something got stuck to the output that goes to the front sprays the rear one is fine, i took the rubber tube of the front sprays and blowed on it, it started working but after a while it got clogged again. now this leads me to believe that its nothing big, just need to take the reservoir out, clean it and put it back in. I've seen that its tucked in, but got no idea what I have to take out in order to reach the reservoir, any help is appreciated.
Re: Sanding door and dash
Take the pass side fenderliner off, you'll know what to do after that.
It's pretty self explanitory once you see it.
Taking the right front tire off will help give you better access too.
