Wheel Stud
This weekend I had a wheel stud break. Ended up going to the dealer and picking up a new one. They are actually pretty easy to replace. All you have to take off is the caliper and the caliper mount. Then it is simply a task of knocking the old one out then knocking the new one in. One thing I noticed is that the new stud seems to be about 1/8" shorter than the other studs. There is still plently of thread that the lug gets to hold onto but wanted some opinions on wether this would mess anything up?
Vehicle: 1997 accent L
You sure its seated all the way?
BTW, for those of you with captive rotors, it aint this easy. It will probably be cheaper to convert to the later 2000+ setup as the entire hub/brake assembly has to come apart since the hub is sandwiched between the spindle and rotor (someone PLEASE correct me and tell me this is wrong btw, as I know I'll end up breaking one this season).
Yeah that was the strange part. It was seated all of the way. I actually bought 2 and held the old broken one up to the spare new one. You could definately see the 1/8 inch difference. They guy at the dealer I got these from wasnt too bright to say the least. They could very well be the ones from the rear. Beats me. It worked and now I dont have to worry about atleast this. Anyway for everyones information the torque specs on an RD2 with A/A rims is 66-81 Ft/lbs on the lugs.
Vehicle: 2004 Acura TL
<div class='quotetop'>QUOTE (skierd @ Apr 4 2005, 11:44 AM)</div><div class='quotemain'>You sure its seated all the way?
Yeah, for sure, unless you have a big enough press to remove and install the bearing again, just do the swap to Non-captive.
