What Happens When Your Fans Dont Have Wiring...
make sure to solder the wires together, electrical tape it then put heat wrap over it. a short will happen if the wires touch like mine happened and now my power doors aren't working. what kind of fans do you have? FAL or stock?
Vehicle: 97 Tib
no no no, solder and electrical tape is bad
soldering doesn't matter, you can twist and do a good job, but if the wires are going to be exposed (like in the engine bay or under the car or outside anywhere) u NEED ABSOLUTELY to use HEAT SHRINK, and after that I like to loom or tape around it. Failure to do this will result in water shorting it out eventually, take it from me...wink1.gif
i was planning on solder and heat shrink. and water isnt an issue b/c it doesnt get that high in the engine... and if it did i would be worried about bigger issue than a short....
ah, didnt think about that. good insight though smile.gif.
anyways, i got the wiring all done today. Heat Shrink sucks to work with by the way..... I soldered it, heat shrinked it. Then just for good measure i taped it up too. (now it also matches! cool.gif ). Thanks for all the ideas guys.
