What is the best way to start with an automatic......??
Old 11-01-2004, 04:16 PM
OdessitPashka's Avatar
Default Re: What should I look for in buyind a Tib?
<div class='quotetop'>QUOTE (zoned019)</div><div class='quotemain'>you know how to sport shift right? and if you use the ebrake in the beginning (although this takes more skill) it will probably help you more than just putting both pedals to the floor.
put your ect on power
take overdrive off
shift into L
pull ebrake up all the way (14 clicks?)
put gas pedal to the floor
when the light turns green, let the ebrake down fast and keep the gas to the floor
when you're at about 6000rpm shift into 2
when you're at about 6000rpm again shift into D
when you're at about 6000rpm a 3rd time put overdrive on
that is how to accelerate fastest with stock automatic transmission
oh yeah, and neutral drops are BAAAAAAAAAAAAADDDDD</div>
NO! WRONG!
1st of all you cant floor your automatic while you are holding handbrake, you will spin, thats what I did on my elantra to warm up my tires. 2nd of all you will not accelerate faster by shifting manually automatic transmission, i've tried it more than once, and tried it at the track, it seems faster, but in the end results are a lot worse if you just let it shift by itself! and when you mess with your transmission like that, you f*ck it up!
Old 11-01-2004, 05:06 PM
Default Re: Haynes manuals
i wish i had a manual.... grrr. how much does a conversion cost? $700?
Old 11-01-2004, 05:18 PM
Default Re: rd1-->rd2 FRONT END conversion
basically it depends on how cheap you can find parts for the conversion.
Old 11-01-2004, 06:39 PM
sharkev's Avatar
Default Re: pulleys
Ok.. thanks, and I know that put it in neutral and rev up and then put D, is very bad for trannys, and thats why I dont do it.....heheh, i nver did it.....
my dream its do the auto to manual, but for now I cant afford it, or the other way its do the level 10, but still cant do it.... so for now I want to know a lot of tips that you people can give me and try what ir the best way to acelerate from stop....
thanks......
Old 11-01-2004, 07:00 PM
Default Re: Burgundy Tib
anybody have any links for him or info on where to get these upgrades? i sure don't.
Old 11-01-2004, 07:28 PM
BillyDee01Tib's Avatar
thats what i meant use two feet and use your regular brakes to hold it in place and rev it as much as ya can, but yeah odessit is right get a manual, auto cars are turds
Old 11-01-2004, 08:37 PM
SuPaDuPa's Avatar
Default Re: fs tons of stuff need to get rid of help
I find if you let your foot off the gas and tramp it again just before the shift it will also shift harder than normal...thats what i do with my automatic when i drag race....also i just sit at the start line and floor it on the last green light
Old 11-01-2004, 09:40 PM
Default Re: FS: evo zefiro hood 97-99
i have a trick i always do: pay attention to the side of the intersecting lights. floor it when you see the corner of the light on the bisecting street hit yellow. you get a 2 second lead off the bat. it's perfectly fair because by the time your light hits green, you're already in full swing lol.gif
does anybody know if you need a level 10 with a turbo :?: ?
Old 11-01-2004, 10:21 PM
Default rd1 shop manual?
http://www.levelten.com/
if you want a chance of your auto surviving with anything over 180whp, you're gonna need to send it to level ten.
Old 11-01-2004, 11:39 PM
<div class='quotetop'>QUOTE (SuPaDuPa)</div><div class='quotemain'>I find if you let your foot off the gas and tramp it again just before the shift it will also shift harder than normal...thats what i do with my automatic when i drag race....also i just sit at the start line and floor it on the last green light</div>
I think this trick does help, but it also ruins your auto tranny. I did that, and when I was changing oil in my tranny and unscrewed the bolt, a whole lot of metal dust, or w/e you wanna call it, drained down, so basically all of these times I was shaving metal off my transmission....
