Went Wrong With My Can
Vehicle: 1998 Tiburon
Hey guys after searching, I still havn't found a positive answer to why my catch can install went wrong. Mounted and everything but my idle is sky high, slowly drops to 1g then climbs again. I have one line from input can to intaake manifold but "t'ed" into my pvc. So I have 2 line running into one side with a filter on the other side.
All hoses are clamped and tight so my thoughts are must be the vaccuum from pvc to manifold is broke at the copper t?? Should I just run a line from the pvc and and one from manifold?
My searching yeilded a fitting on the pvc and one line off the manifold and other line to the atmosphere.
O by the way I am n/a.
thanks for the help
thanks for the help
