Weight reduction info!
Re: FS:1st gen tib. OEM shark racing wing
haha, I'm not that crazy about weight reduction smile.gif As you can see all the stuff that I removed take about 10-15mins of work. If I wanted to go crazy, I'd remove:
door panels, speakers, HU, AC, muffler, HU, glove box, every single piece of carpet, I'd get an aluminum seat, etc... lol
I did remove my floor mats, as well as cover up for spare tire in the trunk, all that together was about 20lbs!!!
I'll keep the glovebox, simply because I store a lot of useful stuff in it, but thanks for the suggestion smile.gif
Stock car weighs anywhere from 2630-2750lbs I believe.
Re: WANTED: Muffler Welder in Chicagoland Area
<div class='quotetop'>QUOTE (Mad-Machine)</div><div class='quotemain'>well, another place that might really be a difference... the insulation on the bottom of the hood...</div>
thought about it as well, that's what etc is for in my list smile.gif but its just way to extreme!
Vehicle: 2004 Acura TL
Re: Weight reduction info!
I've heard that also helps with engine temperatures as well. Less stuff soaking up the heat, so it helps it escape. Do that and raise the hood with them spacers and that'll help you out.
Re: Wiseco Piston GB???
<div class='quotetop'>QUOTE (OdessitPashka)</div><div class='quotemain'>I'll keep the glovebox, simply because I store a lot of useful stuff in it, but thanks for the suggestion smile.gif</div>
As usual you didn't read man.
Take the glovebox out so you can take the face of it off and get the BIG METAL HEAVY ASS PLATE out of the way.
Then put it back together and reinstall the box.
Re: IM choices?
my bad redz, you said glove box in the 1st line and i was like, hmmm no, im not taking that out, and didnt finish reading the rest.
why is that big metal piece there?
and I don't have a sunroof.
