Trimming Splashguard For Cai..
Old 06-29-2005, 09:24 AM
zoned019's Avatar
Vehicle: 97 Tib
Just wondering what you guys found worked well, I used a razor and that seemed to be going good for awhile but then it broke. I still have a little left I want to get rid of so it doesn't flap around when I'm driving at higher speeds.
Old 06-29-2005, 10:05 AM
jToIeB's Avatar
I used a coping saw...
Old 06-29-2005, 10:18 AM
Black01Tibby's Avatar
I used a coping saw as well yesterday when I installed mine. Cut like a hot knife through butter. fing02.gif
Old 06-29-2005, 10:33 AM
Sparticus's Avatar
Vehicle: 97 Tiburon
i used a Dremel... it took a few circular blade things, but it got the job done
Old 06-29-2005, 10:38 AM
Screwdriver's Avatar
I used my sickel knife. Really sharp. Cut through it like butter. You're not gonna be able to screw all the ends of the guard back on.
You might have to rotate the horn a bit to squeeze it in. Good Luck
Old 06-29-2005, 11:11 AM
djshaggy's Avatar
Can any of you take pictures to show what it looks like?
Old 06-29-2005, 01:30 PM
hamhead's Avatar
I do believe I just took a handsaw to it, as I did it at home where I didn't have access to all the special tools. Just measure the CAI, draw a template, and wack away.
Screw, what do ya mean it didn't bolt up right afterward? Mine went back in just fine...
Old 06-29-2005, 01:33 PM
jToIeB's Avatar
Old 06-29-2005, 03:12 PM
well, i dont have the aem CAI, but i would use the hot knife attachment on my soldering iron if i had to do this.
Old 06-30-2005, 08:06 AM
MrPSXplyr's Avatar
i think I can top you all...I used SCISSORS!
I used a white colored pencil to draw out the area I wanted to cut out, and then just went at it...Sure, it didn't cut through it like butter, but I wasn't very creative, and it just had to be done.
Here's some pics (they're a little big - 1152x864)
<span style="colorrange">
https://netfiles.uiuc.edu/cplee/www/...install003.jpg
https://netfiles.uiuc.edu/cplee/www/...install004.jpg
https://netfiles.uiuc.edu/cplee/www/...install005.jpg
</span>
Here's miscellaneous garage work pictures if you want to look:
https://netfiles.uiuc.edu/cplee/www/...install001.jpg
https://netfiles.uiuc.edu/cplee/www/...install002.jpg
https://netfiles.uiuc.edu/cplee/www/...install006.jpg
</span>
