Thinking About Pulleys
i was thinkin about getting the pulley set from SR.com. i know a few of you have them. you feel any gain? are they worth it? if not which crank pulley should i get? obx,jspeed, or unorthadox racing?
Search, it's been discussed. Many folks have had issues getting the SR set to install each pulley, and SR won't fix the issue. I'd get the J SPeed set if you can guarantee you are getting the right pulleys for your application. There are minor differences between the years.
i have a full j-speed pulley set. i say its worth it, not a huge gain but definately noticable especially in 1st and 2nd gear. it made 1st sooo much more responsive, and your car is gonna rev alot faster. i like them but wen i first intalled and went for a drive i didnt notice it right away.
oh and make sure you get the correct belt- with the new pulleys its gonna chatter and squeal in reverse and do all kinds of dumb sh*t.
The only trouble I see with going with the whole set.. I have the Unorthodox Racing underdrive crank pulley. At idle with my fogs on, My lights will noticibly dim while the car is just sitting there. Not really a problem (how often do you need full lighting at idle?) but if combined with the full set, you might start seeing more noticible problems.
<div class='quotetop'>QUOTE (bloodjunkie @ Dec 22 2005, 04:44 PM) <{POST_SNAPBACK}></div><div class='quotemain'>i have a full j-speed pulley set. i say its worth it, not a huge gain but definately noticable especially in 1st and 2nd gear. it made 1st sooo much more responsive, and your car is gonna rev alot faster. i like them but wen i first intalled and went for a drive i didnt notice it right away.</div>
Where did you get the full set from?
I will buy the OBX full set in 2 weeks..... but next week I will go to the DYNO.... so I will get a before and after DYNO readings with the pulleys.... just have to pay 70 bucks for three pulls on it....
Now... some friends told me that the "alternator" pulley affect the voltage and don't charge correctly.... it is true???
