Temp Gauge On The Fritz!
Old 02-21-2006, 07:46 PM
zoned019's Avatar
Vehicle: 97 Tib
It just randomly tells me that my engine is either normal or freezing, it moves all the time, lol.
Recently I've installed airram/bbtb and hondata thermal spacers.
help me fix it please, thanks.
Old 02-21-2006, 07:49 PM
BlackTibby00's Avatar
Maybe just a loose connection on the temp sensor sad.gif Not sure where it is, but a place to start non the less.
Old 02-21-2006, 08:21 PM
lilo shark's Avatar
what does the hondata thermal spacers do for a tib?
Old 02-21-2006, 08:33 PM
Alex01tib's Avatar
it goes in between the IM and the engine to prevent the IM from getting hot and heating the incoming air.
try changing the temp sensor?
Old 02-21-2006, 09:11 PM
<div class='quotetop'>QUOTE (lilo shark @ Feb 21 2006, 08:21 PM) <{POST_SNAPBACK}></div><div class='quotemain'>what does the hondata thermal spacers do for a tib?</div>
Why the hell are you asking that here? Make your own thread.
Old 02-21-2006, 09:43 PM
lilo shark's Avatar
i was just wondering why would you be using hondata on a hyundai after reading this thread.
Old 02-21-2006, 09:45 PM
hondata isnt a hondah apart
itsa company they mak parts for ur cars bvt that dosnt belong with temp gague questions so make a new thread
Old 02-21-2006, 09:47 PM
lilo shark's Avatar
that's all i need to know. thanx...
Old 02-21-2006, 11:04 PM
zoned019's Avatar
Vehicle: 97 Tib
Anyway, where is the temp sensor? I don't think it just randomly stopped working, I'm pretty sure it's something I did when I installed the airram. Do any of those hoses relate to the temp sensor? Is it possible that since I have a CAI, thermal spacers, and it's negative degrees here, that it just reads super cold air coming through, then it heats up, then sucks in more, etc, so it would do that? And is it bad to continue driving around daily with this malfunctioning like it is? It doesn't seem like it is good for my engine to think it's cold when it's really warm. .And for anyone thinking that it might be the needle, that's impossible because I installed gauge faces months ago, and its always worked fine before.
<div class='quotetop'>QUOTE (faithofadragon @ Feb 21 2006, 10:45 PM) <{POST_SNAPBACK}></div><div class='quotemain'>hondata isnt a hondah apart
itsa company they mak parts for ur cars bvt that dosnt belong with temp gague questions so make a new thread</div>
I think faith has had a few tonight..
Old 02-22-2006, 03:50 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
If you disconnect wires from temp sensor (or sender I don't remember..) temp gauge needle will go to cold.
You probably have something with wires or sensor/sender
