Switch To Synthetic..
Old 07-29-2005, 01:01 PM
zoned019's Avatar
Vehicle: 97 Tib
Thanks Jon, that was really the answer I was looking for.
hmm, I might give it a shot..not sure yet.
Old 07-29-2005, 04:42 PM
synthetic is generally cleaner with less contaimenents..
I can tell you this about it: On my Old Excel, I ran Mobil One for the entire time it took to get to 150,000 miles. After that, I slacked off and went to regular oil.. within 5 thousand miles, the car was smoking badly from the valve stem seals... so take that as you see it.
Old 07-29-2005, 04:45 PM
'treezy's Avatar
wut do you generally use mad? Mobil 1 5w-30 or 10w-40?
I've been using Mobil 1 except on one occasion but I will be moving to the hot desert soon. I think i will be fine continuing my Mobil1 habits.
Old 08-01-2005, 07:45 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
Also synthetic oil cleans engine better tham semi-synth.
Old 08-01-2005, 01:29 PM
Mobil 1 10w30 is what I use.. it is the grade that Hyundai recommends and it is carried most everywhere.
Old 08-01-2005, 01:37 PM
tb1198's Avatar
Kind of off topic, but does anyone have an opinion on the Mobil One extended performance oil? It appears to allow for a yearly oil change (15,000mi) rather than every 3mo/3,000 mi.
Anyone???
Old 08-01-2005, 04:23 PM
Zman's Avatar
<div class='quotetop'>QUOTE (JonGTR @ Jul 28 2005, 01:03 PM)</div><div class='quotemain'>The frequency of changes is FAR more important than what kind of oil you use. Just run the regular stuff, but change it frequently.
Agree 100%
<div class='quotetop'>QUOTE (JonGTR @ Jul 29 2005, 01:08 PM)</div><div class='quotemain'>Supposedly synthetic has a longer breakdown period. But ultimately, it's the same. So it isn't gonna be better than dino oil. It may last a bit longer, but it's not worth the extra $3-4 per quart. Basically, you are paying 3 times as much for oil that's not gonna last close to 3 times longer.
You could put in regular oil, change it twice as often, and still come out cheaper with the same condition motor.
^^^^ DITTO.
If you want to put more expensive oil in your car go ahead and do it, but don't do it in favor of longer change periods, after all, no one he is going to bash you for putting good stuff on your car, most of us do it one way or the other, it's like spoiling your Tib a little tongue.gif
Mad, I think your experience is more like a two different events occuring by luck at the same time...
Zoned, don't go with too thin oil either, it's as bad as going with too thick oil when the time comes for the oil to perform in extreme conditions.
Old 08-01-2005, 04:55 PM
generally I will say this.. the day of the 3000 mile oil change is over. With our cleaner burning cars dumping less pollutants into the oil, cleaner, better reforumulated oil, and just plain better engines, it is not necessary to do the 3000 mile thing. I change mine around 5 to 6 with a top off inbetween (my car uses very little oil). This is doubly true for a synthetic.
If you doubt me, look at the new Euro cars with the computer monitored oil.. some of those cars can go 12,000 milesor more before the computer finally notices enough pollutants in the oil to warrent a change.
It also depends on how you drive. Stop and go city driving is much harder on the car and oil than highway or steady speed backroads.
Old 08-01-2005, 06:25 PM
Mad_john's Avatar
i run mobil 1 15w-50/0w-40 or the royal purple, but jon is right they break down slower then real oil
Old 08-02-2005, 07:36 AM
JonGTR's Avatar
Yea, but not THAT much slower, so save your money and change a little more frequently. fing02.gif
