Switch To Synthetic..
Old 07-28-2005, 11:20 AM
zoned019's Avatar
Vehicle: 97 Tib
Well, now that I have a tib with only 50k on it, I am wondering if I should switch over to synthetic oil .. I've read from some people that supposedly our engines "don't like synthetic oils"? If I were to do this I would be investing in some Royal Purple, just wondering if it's all worth it, or should I just stick with my conventional Valvoline cool.gif
Old 07-28-2005, 11:45 AM
I have run Mobil One in my car since the second oil change.. about 108,000 miles ago. Engine is still strong, does not smoke, and barely uses any oil at all.
Old 07-28-2005, 11:54 AM
draguntib's Avatar
Mine was running Synth when i bought it and it still runs great. Hardly uses any oil even when i am late on getting it done. I use Syntec but am thinkin about going to Mobil 1 next time.
Old 07-28-2005, 12:03 PM
JonGTR's Avatar
The frequency of changes is FAR more important than what kind of oil you use. Just run the regular stuff, but change it frequently.
Old 07-28-2005, 01:39 PM
supercow's Avatar
I've been running synthetic for a while now (maybe 30k) and i like it. I change every 3k miles.
Old 07-28-2005, 02:51 PM
BIGTRE13's Avatar
I have only used Synth since I bought the car 80k+ miles no problems.
Keep in mind the car sat for almost 3 years(unmaintained), started up no problems
Old 07-28-2005, 02:57 PM
JL_TIB's Avatar
im still debating running 20w50 or 10w40
but i only use dyno oil and change it often
Old 07-29-2005, 07:55 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I use only synthetic 5w-40
works fine
Old 07-29-2005, 11:13 AM
boostedtib's Avatar
Vehicle: 1998 hyundai tiburon fx
<div class='quotetop'>QUOTE (JonGTR @ Jul 28 2005, 06:03 PM)</div><div class='quotemain'>The frequency of changes is FAR more important than what kind of oil you use. Just run the regular stuff, but change it frequently.
Exaxctly what I was going to say. I just had my first real example of doing your oil change when it's do. I went 3k past the due time and I do believe I fried the turbo bearings. sad.gif I learned a very valuable lesson. drillsergeant.gif But i've been runnig Mobile one from the first oil change 5w-30.
Old 07-29-2005, 12:08 PM
JonGTR's Avatar
Supposedly synthetic has a longer breakdown period. But ultimately, it's the same. So it isn't gonna be better than dino oil. It may last a bit longer, but it's not worth the extra $3-4 per quart. Basically, you are paying 3 times as much for oil that's not gonna last close to 3 times longer.
You could put in regular oil, change it twice as often, and still come out cheaper with the same condition motor.
