Sti Spark Pug Wires?
Old 11-17-2006, 08:17 PM
rusomen's Avatar
i ordered STI Spark Plug wires for my tibby what do you guys think about those ?????
here r options
10.8mm Wire w/3 Layers 100 percent Pure Silicone
Comes w/Marten Rodent Protection
Direct Ignition Cassette
Greatly Exceeds O E and Competitor Specifications
Ignition Module
Improves Gas Mileage and Engine Performance
Limited Lifetime Warranty
Plug Wire Removal Tool
Resists Temp. Up to 1200+F w/Operation At 840+F
Super Conductivity w/Superior Corrosion Resistance
2 Layers Of Fiberglass Braiding For Strength
Contains 19 Strands Of Tinned Copper Core
Corrosion-Resistant/Oversized Clip-Lock Terminals
Double Extruded Silicon-Over-Silicone Wire
Low Resistance Allows Max. Voltage To Spark Plugs
Resistance To Heat/Moisture/Abrasion/Chemical
Sensor Cable
Spiro-Wound Stainless Steel Conductor
Superior Voltage Protection
Unique Tinned Copper Core
8mm Wire w/2 Layers Of 100 percent Silicone
Includes Specially Designed Durable Boots
Interlocking Beads Protect From Gnawing/Abrasion
Over 100;000 Volt Strength w/Protection at 600+F
Prevents RFI From Interfering w/Electrical Equip.
Spiral Core
Connector For Direct Ignition Unit
Direct Ignition Coil
German Engineered High Performance Plug Connectors
Ignition Coil Pack
Stainless Steel Magnetic Conductive Winding
Old 11-17-2006, 08:52 PM
Dweet's Avatar
Will they even work? The boot has to be a certain depth and the wires have to be a certain length. WRX's have a box 4 so I'm not sure on how the length issue will work.
Old 11-17-2006, 09:19 PM
doubt it is going to work.. would have been better to get the PRD wires here from the vender on the site. Ignition is not an issue with the Tib unless you are pushing serious compression or boost
Old 11-18-2006, 02:21 AM
Vladimer's Avatar
Vehicle: 01 Tiburon SE
dont mean to intrude on your thread but.. we have a vender for PRD wires on site? or are you referring to www.prdonline.com
cause im planning to buy a set like real shortly and if theres a way to save $$ on that im all ears smile.gif
Old 11-18-2006, 07:04 AM
lilo shark's Avatar
oem replacement ngk's are good enough.
Old 11-18-2006, 08:36 AM
xxxmonoxidechild's Avatar
on a stock ignition set up..
but the prd's are made to order in whatever color set up you want, and there only 15 more then the ngk's.
Old 11-18-2006, 09:00 AM
hamhead's Avatar
STI spark plug wires will be way too long because of the boxer engine configuration setup... in those motors all the wires are several feet long.
Thats even before having to have the boot a certain length.
Old 11-18-2006, 09:11 AM
I have the NGK's and am going for the PRD's, they are beautiful and have a lifetime warranty.
Old 11-18-2006, 09:12 AM
the only wires off hand i know that will work on our car is the eclipse wires. i had a set of 9mm aftermarkets on mine for awhile of a eclipse.
Old 11-18-2006, 03:19 PM
rusomen's Avatar
guys you got me wrong lol laugh.gif STI it's not from WRX Sti it's company that making spark plug wires lol
STI WEB SITE
STI = (Spark Transfer International)
and i received them already they are direct fitment even number of cylinders tabs there smile.gif
