Screwdriver's 120k Mile Tune Up
The clutch is hydraulically operated just like the brakes and in fact uses brake fluid in the system. You will see the clutch fluid reservoir near where the brake fluid reservoir is. It is a small white plastic container with a black lid. The fluid should be changed periodically the same as the brake fluid is.
<div class='quotetop'>QUOTE (rallyman @ Nov 16 2006, 01:35 PM) <{POST_SNAPBACK}></div><div class='quotemain'>The clutch is hydraulically operated just like the brakes and in fact uses brake fluid in the system. You will see the clutch fluid reservoir near where the brake fluid reservoir is. It is a small white plastic container with a black lid. The fluid should be changed periodically the same as the brake fluid is.</div>
Won't replacing the brake fluid automatically cause the fluid in the reservoir to be replaced with fresher fluid?
I got wipers, Pandy
I got wipers, Pandy
No, although the fluid for the clutch is brake fluid it isnt connected to the same source that the brakes use
<div class='quotetop'>QUOTE </div><div class='quotemain'>Damn! Really?
Im headed over right to Marty McFly's place and I'll get another one.
Anyone with real input, please post.</div>
LMAO... good place to name a shop though.
Coilpack.
Coilpack.
