Safc 2 Help Needed
***** Problem fixed.....was a bad fuse.....******
thanks for the help guys
I recently installed a safc2 into my 2001 tiburon. The problem I am having is that my car will not start....it turns over, it just wont start. I followed instructions posted here as to which pins to hook which wires to and ran the safc setup and everything seams fine untill i go to start the car. any ideas as to what may have caused this ? it ran perfect before i install the safc. I tried to search the forums but did not come up with anything usefull.
Yes the safc does work....it turns on and lets me adjust the settings.....I set the settings to what I found on this site. I will recheck my wireing again today but I am pretty sure it is correct. everything else on the cars works it just wont start so I dont think anything is loose.
Vehicle: Elantra HD / 2007
Does your starter turning?
Check ECU fuse.
Check is there fuel in tank... (sounds funny, but I saw once - two guys tied a car to the shop, car didn't start, they spend there 1 hour, until one mechanic fill in a bit of fuel)
Check ECU fuse.
If it was working fine before, then it's probably something simple like bad wiring, a blown fuse or the ECU connector not properly seated. I would test it in that order: check fuses, disconnect the SAFC harness, triple check that the ECU connector is properly seated (by removing it and plugging it in again).
<div class='quotetop'>QUOTE (Dmitry @ Apr 8 2005, 01:52 PM)</div><div class='quotemain'>Does your starter turning?
Check ECU fuse.
Full tank of gas.
I will check my fuses but I dont think that is it since everything in the car is working and I had the battery disconnected during the install.
the starter is trying to start the car it just wont start?
sounds strange....I was wondering if somehow I connected the wires wrong or in reverse?
Or if some setting on the safc is set wrong
Check ECU fuse.
Full tank of gas.
