S-AFC II base settings
Vehicle: 2004 Acura TL
Anyone using 205/55/15's?
C'mon Dweet is asking a question like this!!! J/K
I dunno man, I came to whore and poke fun. Just Butt dyno it.
Re: S-AFC II base settings
There was a post early in August about this. I found the information on HA.
http://www.rdtiburon.com/index.php?name=Fo...e+settings#5161
Re: Going to Capital Raceway Tonight (1/4 time will be up 9/
it helped a little, but still it didnt have the corrections, however i just took it for a spin and figured it out.. my butt dyno tells me there are significant gains smile.gif
Re: Check out these gauges
As you as you get it tuned correctly and it doesn't fail. If your A/F gets screwed up (either bad settings or a malfunction) you could cause detonation which is bad bad bad.
Re: what do you think about these?????
Dweet, you still banned at HP??
I remember someone posting a program to help w/ tuning in 3D. It was only for the SAFC (not 2) but should still get you VERY close.
If you are still banned or whatever happened....let me know and I'll see if I can find it for you.
And an incorrect A/F Ratio can do serious harm to your engine. But w/ the SAFC's you have to be TRYING to blow up your engine (or a completely illiterate retard) to screw up the settings that bad.
Re: HEADLIGHT warning signal?
Hi Dweet.. I have that program..... But right now I'm in my work... If you can wait like 5 hours more.. I can send it to you to an email.....
I also want to know the base settings to tune UP the SAFC II..... I have no Dyno...
