Rside shifter
Re: Oil LIne
just got it put it, feels better than the stock shifter.
only thing is its loose when not in gear, is it suppose to
be like that? other than that it shifts great. i will
post pics soon.
post pics soon.
Vehicle: 97 Tiburon
Re: WTB: Stock RD2 Wheels
is it loose while in gear or in neutral?? if in neutral.... who cares?! if in gear.... again... who cares?
leave your hand off the shifter, and u'll never know about it...
if it bothers you... make sure that the return spring is installed correctly on the new shifter. i would pull the pic for REDZ dyi, but i'm not up to the challenge right now
i, along w/ many others, have the RSide Advance...and i couldn't be happier. just make sure you followed the DYI exactly, and u'll be all set
Re: Nopi Nationals Sept 18-19
If it's loose at Neutral, you prolly installed the spring wrong.
Or, did you remember to bring the White Plastic Bushings over from your OEM shifter?
Re: Forum Design Change? Collapse Left Frame
Don't Double Post mang, you've been told that before. Use the FREAKING EDIT button.
As for your problem, no clue. You'd have to take pictures. I'd suggest taking the entire assy back apart, looking at my foolproof DIY in the DIY section here, and making sure you have all the proper parts in the proper places.
The ONLY problems I've seen folks have are...
1. Forgot to put the WHITE PLASTIC SPACERS from their previous shifter into the new one, now it doesn't shift correctly.
2. Replaced the centering spring improperly so it doesn't come back to center properly.
3. Forgot the order in which the spacers and all the other small parts on the front and back of shifter go and therefore the shifter doesn't work properly.
