Rpm Going Down Faster ?
Vehicle: 2011 Sonata Turbo
i know it's really a weird question but i was wondering how could i get the engine rev to go down faster between shifting gears....
like what modification could help make the rpm going down faster
i know that flywheel helps and pulley to ? would headers help to ? anything ?
thx Martin
thx Martin
It's designed that way... Not much you can do to help it, but the things you mentioned will help a little.
Search a bit, it's been discussed before.
You could disable the common wire on the IAC with a switch. It might cause a check engine light, but it would probly be the fastest, cheapest way without replacing the ECU.
The flywheel is what makes the engine try to stay at a steady speed, so a light one of course, will let it drop quick.
Trust me, if you haven't driven a tib with a lightweight flywheel, you need to, it takes some getting used to (you'll stall it often for awhile), but the RPM's drop like a brick.
i curently got a ebay 10lbs flywheel..... and i love the diffrence it made
stitch .... why well i saw that when i change gear the rpm don't have enough time to go down so the clutch doesn't really like it.... sad.gif
