Ridiculous Electrical Problem
(This is a 2001 Tiburon)
After a run in with an embankment (long story don't ask 02.gif ) and rather extensive right rear wheel assembly work, I'm having some wicked electrical problems. I ran into this embankment pretty hard, enough to really bend up the back tire. Having it back from the shop now I notice that several components don't work, but they don't seem related. Here's the list of things that DON'T work.
-digital clock
-dome light
-trunk lights (inside)
-trunk-open indicator LED in the cluster
-that annoying bell when you put the key in or when the door is open
That's all I can think of. Everything that I didn't mention works fine. All the A/C lights, the window button lights, all the rest of the cluster (e brake, check engine, seatbelt, gauges), turn signals, the "lights on with door open" dinging noise, etc. Those listed are the only parts that don't. I checked all fuses and they're all good. I can't think of any reason all these parts aren't working anymore. They don't seem connected in any way. Help me here guys, what's the problem?
-digital clock
-dome light
check fuses 13 and 6 in the dash fuse box...
come back if they are bad. i know you said you checked them all, but please double-check. i cant count the number of times someone said they checked the fuses, only to have missed one.
<div class='quotetop'>QUOTE (tibby01 @ Dec 13 2005, 04:55 AM) <{POST_SNAPBACK}></div><div class='quotemain'>check fuses 13 and 6 in the dash fuse box...
come back if they are bad. i know you said you checked them all, but please double-check. i cant count the number of times someone said they checked the fuses, only to have missed one.</div>
Well f*** me. 6 was blown! Why didn't I check that one? Replaced it and it works. 02.gif Thanks man, problem solved.
