Radiator question/help..
Re: THE RETURN OF THE NFL!!!!
Does anyone know of a radiator from any make/model that will fit (w/o major complications) in a 01 Tib.?? I can't find a Tibby radiator without having to sell a kidney to afford it. Any help or suggestions would be Greatly appreciated.!!
Vehicle: 2000 Tiburon
Veilside Hood & Wing
Hmm... I seem to remember someone from HP.com trying to run a GB on some a while ago... maybe he/she can get one for you now. I don't remember how that GB went though. My comp is not loading HP.com for some reason but try going there and doing a search.
http://www.hyundaiperformance.com
Re: 1998 tiburon factory parts
I beleive somebody said that the Evo8 radiator will fit.. but I doubt that is much cheaper than the Tibby one...
Exactly what is the Defination of "Selling a Kidney"? A couple of hundred is what I would expect to pay for most radiators... unless you car is a limited production, mid engined, Italian Antique... then you might want to spend $900 IF you can find one...
Re: denting/bending header??
Yea, a couple of hundred is way more than I can pay right now. Someone hit my car and busted the radiator among other things. Therefore, I havent had a ride in 3 weeks. I have so many other things that I have to buy for the car, immediately, that I'm having to cut every cost possible.
I was hoping that I could use a radiator (atleast for a couple of weeks) from another car that I can actually find at a wrecking yard, etc. I wouldnt care how it looks or anything, as long as its functional. Any ideas, I'm desperate oops.gif
Re: Cigarette Lighter not working.
Re: Crappy MPG on Tiburon
Yea, I've asked everyone that I have spoken with if they have a radiator for a tiburon or elantra (I assumed they are the same) but, no luck.
I has hoping that I could find one from a more common car for $50 or less that would work temporarily. Any idea what cars have a radiator close to the same size as the tibs?
Re: Exhaust question for FI engine
<div class='quotetop'>QUOTE (Mad-Machine)</div><div class='quotemain'>I beleive somebody said that the Evo8 radiator will fit.. but I doubt that is much cheaper than the Tibby one...</div>
it wil fit but not perfectly. but it will perform ALOT better, but yes it will be more expensive
