Question For You Wiring Experts
Vehicle: 1998 Hyundai Tiburon
My cruise control has not worked since I did a motor/trans swap. What needs to be rewired to get it to work with the manual trans? I put in a new cruise unit and it is getting power as is the switch on the dash but the cruise light won't come on in the gauge cluster. I have searched for the answer and came up with nothing. Please help.
Search no more.
Go replace your LED bulbs with regular bulbs and your cruise will work.
I posted about this about a year ago.
And brought it back up a few days ago.
http://www.rdtiburon.com/index.php?showtop...=cruise+control
It might. No one has tried it as far as I know.
LED bulbs are not legal for road use anyways, and I almost got hit too many times from behind because the bulbs aren't bright enough to see during the day.
Just swap em out, or give the resistor loads a try.
Vehicle: Elantra HD / 2007
<div class='quotetop'>QUOTE (REDZMAN @ May 17 2005, 08:23 PM)</div><div class='quotemain'>LED bulbs are not legal for road use anyways, and I almost got hit too many times from behind because the bulbs aren't bright enough to see during the day.
what about cars that have LEDs tail lights in stock?
If you mean those LED panels for taillights, that's different. They are approved.
