Pulleys Are In...except One
Old 11-08-2005 | 09:19 AM
Yes, it was sarcasm. SR is not known for good customer service, good parts, or good business practices.
Old 11-08-2005 | 10:19 AM
Screwdriver's Avatar
1st:
Yes the crank pulley is an underdrive one. I wouldn't worry about underdriving too much. It's the balancing element of pulleys that are a cause of concern. From what everyone has told me, we are fortunate to have balanced engines.
2nd:
<span style="color:#009900">You can trade with me. </span>I have a round Power Steering Pulley and I need a splined one for my pump. You have a splined one and need a round one. An even trade.
3rd:
The Water Pump Pulley is the hardest to install because of the location AND the least impactful. The OEM WP Pulley is light. The aftermarket pulley is around 30-40% lighter, not alot of difference is going to be felt. You will have to lift the engine 3-4 inches after unfastening the front engine mount. That makes it alot easier. Then, just screw it on to the Power Steering inner pulley and you should be set.
Old 11-09-2005 | 06:24 AM
Grottenolm's Avatar
Redzman and Screwdriver thanks for your help.
<div class='quotetop'>QUOTE (Screwdriver @ Nov 8 2005, 06:19 PM) <{POST_SNAPBACK}></div><div class='quotemain'>2nd:
<span style="color:#009900">You can trade with me. </span>I have a round Power Steering Pulley and I need a splined one for my pump. You have a splined one and need a round one. An even trade.</div>
Sorry, my mistake... I have a round and need a splined. So same problem here.
Old 11-09-2005 | 08:45 AM
DAMN!!!
Here is what SR's response was:
Aviv,
As we state on the order page, the original red water pulley sold out,
so we made new ones. The other pullies, the power and crank pullies,
when they sell out, we will also get them made in the silver.
For the water pulleyk, have you tried installing it yet?
Old 11-09-2005 | 10:40 AM
LMAO
That's typical SR bullshit.
The reason they "Sold out" is GIM was a shitty MFR and went out of business.
Get a refund, send them back, I can hook you up now that I know what to do.
Old 11-09-2005 | 11:31 AM
Im going to ask for a refund for just the PS pulley. I like the other two where they are (replacing them would work out too time consuming and not worth it IMO)
If you get splined PS pulleys made/ sold, I'll take one. Otherwise, I'll make do with what I've got.
Old 11-09-2005 | 11:35 AM
You COULD press that pulley on like Tibbytib did.
Old 11-09-2005 | 11:44 AM
Jaws021's Avatar
This mod seems a little too complicated and expensive for the little impact it has on performance.
Old 11-09-2005 | 11:45 AM
No worries Jaws, I'll be having a full kit setup on Kspec.com for these soon, Jspeed Pulleys too.
Only thing you'll have to get is the belts, but I'll post the sizes.
