pulley but no belt
Re: what gauges to get for boost??
on ebay ive seen power pulleys and crank pulleys for 00 tiburon, but they dont come with new belts. will that hurt performance os will just the new pulley help?
pulley but no belt
the theory behind the pulley is that its lighter.. has nothing to do with the belt, although you might as well change the belt when you put the pulley on. some require new belts that are different than stock belts because the pulley is smaller so you have to use a new belt anyway
Re: TICKET
You might have to buy a new belt depending on the pully. If it dosn't come with one, you can always buy one that will fit from AutoZone or any auto parts store. Just make sure you have a ride to get there.
Re: The Legitimacy of our 1/4 miles
what do you think i should do? on ebay, crank, water power steering pulleys add up to about 170 without belts, on sharkracing.com i can get them for 240 with belts.
Re: Gmail
belts are cheap BUT it can be a process of elimination to find out the correct belt size. Like I said earlier, make sure you have a ride to go back and forth from the auto parts store and it should not be a problem. The tension pully can also be adjusted somewhat so that will help with the belt. As far as the differences between pullys, I don't know about the ebay ones, but I do have the Sharkracing pullys and they work well.
the ones on ebay are obx, but with no belts, i think it would be easier if i got the SR ones because as u said they work well and come with new belts already
Re: dyno
BlahBlahBlah everyone puts down SR. I bought these pulleys and they came in 4 days. Not only that but there was some problem charging my ccard so I ended up getting charged an extra 6.50. They responded to my emails the next day every time I tried to get ahold of them.
The pulleys are great that SR has. I have shopped there 5+ times so far and I have no intentions of stopping.
The OBX power steering pulley will NOT fit an RD2. Also the JSpeed power stearing pulley @ KSpec will NOT fit a Beta1.
