Problem Starting
Hey guys i need some help here. Alright here is the problem, i will go get gas and then after i get more then say $10 to $15 my car will have a trouble starting. It will not seem to turn all the way over, and after about 5 seconds i will turn on then it will be idle rough. It will want to stall but once i get down the road about a mile it will be find and it will start fine after that till i get gas again.
Any Ideas
Help me please.... its annoying
Any Ideas
Fuel Injctors.
Check that they are operating properly, not clogged.
I replaced mine when they were doing the same thing. But I was also experiencing lag when accelerating.
hmaservice.com/webtech can help you with everythign you will need to know about checking resistance of fuel injectors and replacing if you decide to.
For now, run a can of fuel injector cleaner (liquid B12) in gas tank. (full tank of gas).
