Problem With Cruise
so a while back i took my dash apart to install my led hvac. when i put it all back together my switch for the cruise control wouldn't even light up. i assumed i must not have plugged the harness in to it. but recently i took it apart again to install my gauges and i made sure it was plugged in. still doesn't come on
the first time i had it apart i cut the wire to the "ding box" so it wouldn't ding when i had the keys in and door open.
i also think i have the wrong bulbs in my brake lights, not led just not the right kind.
but i don't think the bulb would have anything to do with the switch on the dash. it doesn't even light up when i turn on my lights.
the fuse have to be good because everything else that is ran by that fuse works fine.
*i am not talking about the light on the cluster, im talking about the switch on the dash*
Any thought?
Any thought?
Check to make sure that the cruise control is actually not working first. Go do 45mph, push the button in on the dash regardless if it lights up or not, and hit the set button on your windshield wiper stalk and see if the green "cruise" lights up on the instrument cluster and it is working. The reason I say this is since I pulled my dash apart a month ago and put it back in, the light on the button hasn't worked, but the cruise control system still functions perfectly.
alright ill try it tomorrow on my way to work.
nj, you the man.
i gave it a try and it works. i dont understand it but i can deal without the light.
thanks
nj, you the man.
thanks
The light bulb itself may be burned out. Just do a simple power/ground test on the bulb socket to make sure that's not the problem... or do you have to pull the dash for this procedure? I'm not familiar with RD2's
If you say the tail light bulb is the wrong kind, then replace it. The tail lights are part of the cruise control circuit and if you're having a problem, that's a cheap way to eliminate 1 easy thing from the question.
Well, it looks like the problem could lie in the connector in the dashboard, with the light or the switch itself. It would be odd for the cruise control light to go out. They don't usually go out.Attachment 513
