Power Steering Problems. Cant Stop The Noise!
Old 09-07-2009, 01:07 PM
supercow's Avatar
all the time or just when you turn the steering wheel?
Old 09-07-2009, 09:10 PM
archsvile's Avatar
It makes the noise all the time. When I rev it you can really hear it. Like it has air in it. I bleed the crap outta it for like 2 hours. I bleed it how hmaservice.com tells you to. I think there mixed ps fluid in my system could that be causing it to make noise? I've tried 2 pumps so far and no luck. Whats the best way to replace fluid? and you think I should add a quart of that lucas oil addictive into it? I took it to the other dealer near me and they said I need a new pump. They told me I need a OEM pump.
Old 09-08-2009, 06:25 AM
Sometimes Hyundai parts are MUCH better OEM, no joke.
Did you try different belts? Loosening, tightening, or belt dressing on the belts?
Old 09-08-2009, 11:21 AM
archsvile's Avatar
Yes I played around with the belts. I'm going to flush the fluid today and see if that does anything.
Old 09-08-2009, 02:26 PM
SR Tech's Avatar
Vehicle: 2011 Tuscon
did you happen to install a new w/p at this time aswell? after i changed mine with the timing belt it made the same squeel your talking about, faulty pump... replaced it and volia
And the PS pump and the WP happen to be fairly close to eachother soooo..
Old 09-09-2009, 12:25 AM
archsvile's Avatar
Nope waterpump wasnt replaced. Just repalced fluid today and that didnt do it. I guess I jsut have bad luck and need to get a new oem pump.
