Posted Dyno Sheet Of My Dyno
well as most of you know i did my dyno a couple months ago and never posted a dyno sheet. well heres the dyno and a/f ratio. how bad is it?
A/F
http://i8.photobucket.com/albums/a17/mb1604/dyno2.jpg
DYNO
http://i8.photobucket.com/albums/a17/mb1604/dyno.jpg
A/F
DYNO
looks likean N/A set up ;-)
get rid of the rich spots,especially near 4100 rpm
lean it out all across to around 13 -13.5 A/F
you should pick up a few horses just by tuning it and car will feel much better
Its not too bad, but the car does get rather rich toward the higher RPMs. As said, 13.0 AF would get you a nice chunk of power back.
What is the compression on the engine as of now? Still at where it should be, or is it weakened?
Its usually best to tune on for the hottest possible situation (especially if you are tuning to tight specs) this way no matter what, you will not have a detonation issue with temperature changes.
so when i get an afc and tune i should do it in 3rd rite? and i should make it about 13.0-13.5 the afc can have to maps rite? what should it be at for normal driving or fuel saving?
