Porting Intake Manifold
#25
Lol I'm torn guys...
It's either a- Port and Polish OEM IM manifold, or b- buy an Airram!
Question -- will the ported OEM manifold sound different because of the additional airflow, or will it sound pretty similar to stock?
#26
It will sound similar. If you are going boost go Airram.
If you are goin NA go Port and Polish stock IM. Unless you plan on making an NA BEASTLY tib.
I have a stock IM manifold (1.8L beta) for sale. 40 bucks, I can ship it to you or to whoever you want to port and polish it for you.
I would port and polish it myself up here, but that is nearly impossible in prescott, AZ. So 40 bucks for IM w/ stock bore and then bore it yourself (plus shipping of course). Great deal if ya wanna save $$ on the airram.
#28
the air ram gave me good gains from 4500 rpm and up
before that i had a ported and polished stock int. manifold wich is now on agarwal's car
my car always ran a bit faster then other beta swapped accent over here so i guess it's a part of my "succes"
but i do have some cams and most other N/A bolt on goodies
yes the Throttle bodies we have are stock rebored ones,
old TB is completely disassembled,housing and levers are glassbeaded, slot in shaft is enlarged, on some i do the "half shaft" method,lever are primed/painted,a 58mm new blade is made from t6 aluminium and everything is put back together
