Poly Exhaust Mounts
I bought las week two sets of poly exhaust mounts. Four mounts in total (only needed three but they come in sets). I was having problems with the rubber mounts giving way too much. Since I have installed these mounts the exhaust is held much better and does not travel half the distance it did before. Here is a pic and the guy that I bought them from if you are interested. BTW they can only get them in blue and yellow.
Ebay Store
Ebay Store
Hope you didn't pay more than 5 dollars for them. Usually, if your exhaust is swaying a little too much adding another mounting point in the right place will do the trick.
Sure I will just make on lol. Thats alright I would rather actually fix the problem. Same concept as removing your stock rubber engine mounts with poly ones. Seems pretty common sense.
does he carry polyurethane muffler belts too? I've been looking everywhere!
*Mad Mod Edit*
Man, I do not mind the Muffler belt commments.. as long as you keep them in with a real comment on topic..
*Mad Mod Edit*
Vehicle: Elantra HD / 2007
When I installed my flow-though muffler I used one (the rearest) mount from Ford (I don't know what model, should be not new). Now I can't move my tailpipe.
One mount cost me about $2
<div class='quotetop'>QUOTE (Mad-Machine @ May 15 2005, 01:02 AM)</div><div class='quotemain'>how about noise? do they transmit more exhaust roar to the trunk area?
Actually less Mad. See the MBRP uses one less mount than stock so the pipe over the rear cross member hits sometimes due to the amount of travel the rubber mounts allow. These completely fixed the problem and don't give any more vibrations or noise into the car.
Odd... never heard of these things before. Ahh well, my pipes don't have any scratches or dents from hitting on parts of the underbody so I guess I'm straight. tongue.gif
