Pic Request: Airram Hose Details
My guess is your idle is high because you are pulling the throttle cable, with the throttle body out of the stock position. Remove the throttle cable from the throttle body to verify. If idle remains high with throttle plate shut/no tension on the pulley, your problem is elsewhere.
