Passenger Side Power Window Dead
Old 05-18-2009, 02:36 PM
Dark2400's Avatar
Got one, main switch works as said, othre side is 95% dead. Colors are mixed up, but thats details.
One thing, when Im on the main switch, pressing up for passenger, the passenger clicks, and the solid yellow wire gives power. Other than that, no mix of things work. Power was on, no constant 12v anywhere in passenger.
I tried switching the regulator, no dice, and it was regulator+motor. Tried switching out the passenger side switch box, nothing. I think it's the wiring between main switch and passenger, or something of the sort. Any ideas on how to check/replace that?
Old 05-18-2009, 09:00 PM
You need to hunt down the wiring diagram. Unless you have mice, it is moderately unlikely to be wiring.
Old 05-18-2009, 09:34 PM
frozen's Avatar
Vehicle: 2001 Tiburon
Old 05-19-2009, 12:17 AM
Dark2400's Avatar
I dont understand the wiring diagram one bit. Any help?
Old 05-19-2009, 07:52 AM
That looks fairly simple (aside from the multi-component switches) I'll try to remember to look at it later, but at a glance it looks like a bad pass. side switch could make it not work, even with a good driver's side switch.
Old 05-19-2009, 08:33 AM
frozen's Avatar
I kind of ignored the clicking last time, but if you've replaced the pass. switch I think the problem is most definitely the drivers side switch. You should hear a click in both the up and down functions on the pass. side when controlling from the drivers side.
Otherwise a wire is loose somewhere... There are two connectors in line, MD01 and MD02, somewhere, one may have come loose. On hmaservice there is a connector location index, can look up where there are and check them out. I'll get around to it in a day or two if no one else does.
Old 05-19-2009, 05:03 PM
lilo shark's Avatar
my is screwy. sometimes i can open and close the window and sometimes i can open it but cant close it. i have to press down on the passanger side then i can reopen and close on the driver side.
Old 05-19-2009, 10:01 PM
Bingo. If you can get intermittent operation by messing with switches, you have bad switches. They shouldn't cost too much at a junkyard, or ask one of the members here who are parting out their cars.
Old 05-19-2009, 10:06 PM
Dark2400's Avatar
I can try swapping out the master switch, but if that doesnt work, where on the car should I check the wires?
Old 05-20-2009, 08:02 AM
The doors and dash, probably, but try the driver's switch first. Did you get a *new* pass. switch?
