Overdrive Question
when do you turn your overdrive off? I have an auto tib and i heard that if you turn your overdrive off when you are going at slower speeds (i.e driving through town) it saves of gas mileage. just wanted to know what other people had to say about this. I just dont really know why you would turn it off.
Vehicle: 2015 Subaru WRX
it saves gas when it is on...
It is supposed to give you a little more power if you are going to tow something or are going up a really steep incline. (its kind of like shifting to a lower gear without having to actually shift.)
Vehicle: 2000 Tiburon
Wow, you just spat in the face of everything I thought I knew about overdrive. Are you sure your right?
I was under the impression that you saved gas if you were on the highway with it on and that if you needed to tow something or go up a steep incline you left it off and went into one of the other gears(ie. L or 1 or 2, depending on the car).
Overdrive is an additional gear that is used for dropping engine rpm while driving at speed. The purpose is to decrease engine noise (and wear) and increase fuel mileage. Generally speaking, the increased mileage comes at the expense of decreased power; that is why the transmission will shift to a lower gear when you try to pass someone on the highway.
So do not use in stop-and-go driving where your top speed doesn't get very high, the trans will probably shift to OD everytime you get a little speed and then back off the throttle. This winds up unnecessarily shifting back and forth from OD, wearing on the trans.
SO, I would say that when it is on... and you are on the highway (as Tiburonmoo said) it will improve gas milage.
Switch it off to tow and in stop and go traffic or when you are going at lower speeds.
(which is what I thought I said that first time... but when I reread, heh, I wasnt very clear... sorry guys wink.gif ugh.gif)
well in a country like where I am and there are no trucks (for the most part) cars are the primary means of towing... Ive seen a RD1 towing a medium sized camper before... kinda funny really.. lmao.gif wink1.gif
